13-04-2024 05:28 PM
i am having problem with the battery life of my s24 ultra. It is continuously decreasing estimated battery timing. It started from a full battery would last around 2 days and is continuously decreasing. While on idle it drops more or less at around 1%/hour and while using it drop continuously.
I have attached ss to show my exact usage. Also i have set setting to cut of charging at 80%.
I am not sure if it is good enough or i am just overthinking.
15-04-2024 06:23 AM
So finally today i woke to this. Hopefully it will further improve with time
15-04-2024 07:50 AM
It will.
Battery performance keeps improving and around 6 weeks you begin to get the stable battery usage. Of course, this will still depends on usage. No phone will last 2 days of intense gaming or any intense activity..
15-04-2024 08:05 AM
17-04-2024 01:30 PM
Are you sure that phone has a learning phase and battery will improve post 1 month usage? As i am laso facing the same issue so was skepticall about the phone performance
17-04-2024 01:58 PM
I am Not so sure about it. Its just a guess. Honestly speaking, after 2 years of use my poco f3 is still having more satisfactory performance than s24 ultra as far as battery is concerned.
Battery drainage is rapid when you even use it for very basic functions like whatsapp, calling etc. So far only idle battery performance has improved in my s24 ultra.
17-04-2024 02:28 PM
Even i was using one plus 7t and was more happy with its performance rather with s 24 ultra. Lets hope the battery stays more than anticipated and we dont need to move around service center
18-04-2024 06:55 AM
This happens every year with the S series. The phone shows "very poor" battery performance during the learning phase and the a weeks after but then it settles and has good battery performance. I was charging my S22 Ultra (Exynos) every 3 days after almost 2 years of use.
My S24 Ultra could barely do a day with one charge. After the learning phase, it gradually started to improved and close to 6 weeks it started to show excellent battery performance.
I charged it yesterday, it predicts that it could last over 4 days and it has 90% battery left. See screenshoot below.
battery life
05-05-2024 09:43 AM
I got my s24 ultra 6 days ago and I have 12 hr sot is it good I should let it stay more or factory reset ?
05-05-2024 09:45 AM
I got mine like 6 days ago first I had a bit over 10 hr sot the 4th day I got like 11 sot yesterday I got 10 agan now 12hr sot is it good or ?
05-05-2024 10:57 AM
Hi @Da1RiuS
Your phone is on the learning phase still. It will gradually start to get better and better and within 6 weeks more or less, it will be stable. The battery life is excellent. You will need to be a bit patient.
My S24 Ultra was a bit like that. I could barely do a day and gradually got better and around 6 weeks it started to report over 4 days for a single charge. Of course, that gaming and watching videos will never get that battery life.
