Battery problem
(Topic created on: 10-12-2024 03:32 PM)
sam242p
Hello
Anybody help me why F battery drain quickly . Is there anybody suggested me which phone is good long battery. Samsung and iPhone same no battery improve. Without using battery drain every minute
2 REPLIES 2
lminvti
Samsung Members Star ★
Hey @sam242p
There's few things you can try.
Go to settings > battery and see which app or apps draining most of the battery also in battery settings you can turn on "put unused apps to sleep "
See what app is draining the most. Try reinstalling the app or apps.
You can open phones dialer:
Type *#9900# scroll down until you see batterystats reset press on it (autoblocker has to be turned off and you should use stock samsungs phone app)
Try wipe cache partition
Turn off your phone, plug into PC, tv etc via USB Then press and hold power button and volume up until samsung logo appears Then quickly release power button and keep holding volume up until reboot menu appears then navigate with volume down button till wipe cache partition press power button Restart your phone.
See if any of it helps
BandOfBrothers
Samsung Members Star ★★
@sam242p
Perhaps try a forced reboot by holding down the volume down key and power button simultaneously for more than 7 seconds to restart it. When your phone resets, you will feel it vibrate.
Put any apps that are using lots of resources into Sleep and deep sleep area.
If you perform a forum search you may find existing threads with some further help or guidence within in regards to relevant troubleshooting steps.
If i can be of any further help please don't hesitate to ask  😎
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
