Anyone facing battery drain issues in s24 ultra
(Topic created on: 07-03-2024 10:21 PM)
SIMMAR
I am facing battery drain very fast on my mobile I don't know why it's really very quick draining
12 REPLIES 12
hweise85
So as you know I've been dealing with the same issue, literally since Wednesday. Just randomly it started. I saw on a board here that the work profile has been the issue since an update. Since I have a work profile set up on my phone, I thought I'd give it a try. I turned that off... And it's like magic. My phone is back to charging correctly to actually 100% and the battery isn't draining nearly as fast.
So I'd suggest turning off the work profile and see if that helps
SIMMAR
What kind of work profile in mobile i don't know
Aklima
Big Cheese
Yes, mine went from 100% to 5%
