S23 battery drain following One UI 7 update
(Topic created on: 04-05-2025 09:04 AM)
jamesefc1991
Pathfinder
Battery seems to going quite fast on this new update compared to oui6 any solutions I dont..want to do a factory reset and lose everything
141 REPLIES 141
Piper123
Samsung Members Star ★
Translation
No, my phone has been better than before and lasts much longer.
S24 Ultra
Kennytkg
Just updated my S23 ultra one UI 7 and the battery drain is real. Very bad update this time round
tonyh01
Hi
What do I need to do about the battery drain on my Samsung galaxy s23 after updating to ui 7
Thanks
BigBounce
Reduce screen fresh rate to 60hz and screen resolution to 720p. This should help a lot
GoanGeek
Hi and welcome
Seems like lots of people are having difficulty with the latest update on the S23 series.
A couple of things you might want to consider
1. Battery life can take a hit after an update, so keep monitoring for a week or so.
2. During the week after an update, keep checking for app updates in both Samsung and Google stores.
3. A good old simple phone restart can do wonders.
4. Consider a phone 'wipe cache ( check YouTube videos on it)
5. You can also consider RESETTING your settings only.
Do let us know how you get on.
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
Tourbillon De La Vie
johnz237
SuperStar
After the update- the battery needs to go through 14 days of calibration. Then itll go back to normal
*it can also be an app causing this- all updates fully done?
MGLeon
Pathfinder
Kill any apps running in background
Piper123
Hey there and welcome to the Samsung UK and EU Community Forum
1. 14 day battery optimisation for one ui7
2. Wipe Partition Cache
3. Rogue app likely to be cause
S24 Ultra
Moranblue
Hi all since the last UI Update I've been having issues with my battery draining quick. Expamle my battery has on about 49% checked my phone about 40 mins later and its off the battery had died. I'm also having issues when it is charging. Yesterday it was stuck on 32% for ages. I took the charger out and turned the phone off plugged the charger back in and it jumped to 96%. I'm using as S23 Ultra.
To give an update. Still having the same issue. I can lose 15% - 25% in a matter of minutes. Tonight I put it on charge. Checked still saying 22%. I turned the phone off and back on suddenly its goes to 77%. However within 10 minutes I've already lost 10%. Its crazy. Ive done all the checks that I can with out finding an issue with the phone or the battery yet its still happening. Hopefully the guys at Samsung are taking note and can do something. Ive spoken to a couple of friends who have different years of the model and they don't seem to have the same issue as those of us with a s23.
