29-09-2023 10:47 AM
- Mute
- Highlight
hello. i have 2 Samsung original 25w chargers.one came with my note 10 plus.one with a72.
both of the charger have stopped showing superfast on my s23 after update.it only shows fast charging .I have gone through all the solutions including wiping the cache partition to no avail. so I decided to post here and ask for help.
it also has this problem on a 34 and a54 of my friends but shows superfast on the old s21.
what is Samsung ding here? please help.
29-09-2023 12:52 PM
- Mute
- Highlight
@davidpaterson: After connecting to your charger, please can you try heading to Settings > Battery and device care > Battery, then check the status bar at the top of the screen. Does it reference the Super fast charger connection here?
29-09-2023 01:38 PM - last edited 29-09-2023 01:48 PM
- Mute
- Highlight
i have the same problem
29-09-2023 01:56 PM
- Mute
- Highlight
hello AndrewL and thanks for helping.
no it shows green circle at first and in the menu it shows fast charging. some of my friends have this problem too, they hadn't noticed until i asked them to test my charger on their phones.
it seems to be a change in the new oneui OSes and newer phones that has resulted in this problem ,we didn't have this problem before. some older phones like s21 don't show this problem when we tested them. i believe the charge time is not really different from before but the wording is wrong.it must write super charging not fast. do you think it would be useful to measure the speed with a wattmeter and report back to you? may be that can help you in finding the core of the problem?
29-09-2023 01:57 PM
- Mute
- Highlight
hope Samsung solves this.
29-09-2023 02:51 PM
- Mute
- Highlight
29-09-2023 03:13 PM - last edited 29-09-2023 03:15 PM
- Mute
- Highlight
doesn't work. I have already done the suggested solutions like soft or hard reset, wiping cache partition.it is not just phone either please read my post . it seems to be OS problem.
29-09-2023 03:59 PM
- Mute
- Highlight
29-09-2023 04:06 PM
- Mute
- Highlight
29-09-2023 04:17 PM
- Mute
- Highlight
Mine writes fast charge and green circle.
Thanks for the help.i hope samsung fixes this problem.i prefer not to use beta because I had some bad experience before.
