One Ui 7 and Android 15 battery drain
(Topic created on: 26-05-2025 03:25 PM)
TornadoJoe
Anyone noticed their battery usage really been impacted post-installation of the subject software update? Much higher battery use than before despite optimisation.
43 REPLIES 43
Muzz__
Tourbillon De La Vie
Samsung Members Star ★★
Try diagnostics via Samsung members app and maybe contact support
Muzz__
Tried everything
Adamksc
Troubleshooter
-----------------------------------------------------------‐----------------------------------SAMSUNG Galaxy S23 Ultra SM-S918B /DS
Samsung One UI 5.1 / Android 13 CSC-EUX
Joeeye
Legend
It depends on the apps and services you use. My S25 Ultra on OneUI 8 beta is pretty decent, about the same as I was getting in OneUI 7.4yxkcYLHrf.pngh7Uv4oqBSj.pngChOVgYFIRJ.png
ffizo
After the One UI 7.0 update on the S23 series many users noticed fast battery drain slow charging and wrong battery info showing. Even doing a factory reset did not fix the issue. This makes it hard to use the phone daily. You are not alone  others are facing this too
Al_Edinburgh
The battery seems to run out quite quickly after updating to One IU 7.0 / Android 15. Any advice would be really appreciated.
Wipe phone cache partition
akkrish
Since updating to One UI 7 with Android 15, I’ve noticed a significant increase in battery drain compared to the previous One UI 6 + Android 14 setup. Additionally, the device occasionally becomes noticeably warm during regular usage, which was not an issue before the update
chi17
This doesnt work. 3 charges in a day? Never happened to me before UI7 upgrade. 1749190343330.jpg
