One Ui 7 and Android 15 battery drain
(Topic created on: 26-05-2025 03:25 PM)
TornadoJoe
Anyone noticed their battery usage really been impacted post-installation of the subject software update? Much higher battery use than before despite optimisation.
43 REPLIES 43
keith30
Legend
Ii wouldn't think having a S25ultra is an older device like your referring too. Even the battery drain is effecting some users of that model. So don't talk off your head with your easy fix.
Piper123
Samsung Members Star ★★
Because we have repeatedly answered the same question yet (new) members don't follow forum etiquette and search first.
If I've answered this question over 100 times I wouldn't be surprised. Getting a bit fed up with it as are other regulars in here.
I am not employed by Samsung nor do I receive any remuneration as a Samsung Members Star.
My device is an S25 Ultra.
GoanGeek
As I have mentioned in quite a number of other posts.
Battery drainers
1. Always ON location and always ON background data.
I have seen Google services up in my battery stats which by default uses the above and most are needed by system.
I'd just wait for the next update as at this point.
Specially if OP hasn't installed any other apps or changed settings besides found the update.
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
smg1
Troubleshooter
Just don't reply. Leave the replies to those who want to help others. Being a members star you are supposed to show kindness too
smg1
Troubleshooter
Reported
Piper123
Indeed we are and indeed we do.
GoanGeek
Appreciate your helping . Please don't stop. Some of us are just grumpy old men here 😊
You can always check my posts under my profile. Mostly my s21 ultra s24 ultra ones 😊
GoanGeek
I have a habit of fully Factory resetting my phone after a major OS update or once every six months.
But then that is me and I'm cuckoo head. But it has served me well 🙏
smg1
Troubleshooter
I only do a full factory reset if the clear cache partition hasn't solved my problem and there seems no other solution. But you are not a cuckoo head. Just someone who loves a perfectly working phone
JAMES4578
Samsung Members Star ★★★
@TornadoJoe After the update your device goes through the learning phase again which can take up to 14 days, there may be a bit of a hit even after clearing the cache partition.
you could also try a Battery  stats Reset, with the Auto Blocker turned off dial *#9900# in the Samsung phone App.  scroll down to Batteystats Reset ,tap that and Restart Device.  This has also been mentioned recently by @lminvti @Moiramon  and  @Piper123   recently.
However there may also be a fix in the works whch will improve matters further.
