op 07-11-2023 12:28 PM
Opgelost! Ga naar oplossing.
10-11-2023 10:40 AM - bewerkt 10-11-2023 10:42 AM
op 08-11-2023 09:38 AM
Hi @Bqnaan, good morning.
Thank you for reaching out to us and what awesome to read you've chosen for the S23 to follow up your S20+ 💙 What kind of earbuds do you use? And are these up-2-date?
Kind regards,
Martijn
op 08-11-2023 09:50 AM
op 08-11-2023 09:56 AM
08-11-2023 11:20 AM - bewerkt 08-11-2023 11:30 AM
op 08-11-2023 11:47 AM
Thank you for getting back in this. I don't see an option at the Bluetooth settings when I use a different brand of headphones (AKG) and also when I use my Buds Pro I don't see something similar in the Wearable-app.
Via the Samsung Members-app you can also send in a suggestion to my colleagues of the R&D department. They can investigate this and perhaps this will be added due an update.
Kind regards,
Martijn
op 08-11-2023 11:57 AM
op 10-11-2023 10:43 AM
