20-05-2024 10:56 AM
20-05-2024 09:52 AM
Since 2022 Feb I am using S22, battery backup was fine during 1st year. Then it started decreasing. I had to charge twice a day.
But, just 3 days back 17th May,24 I got a One UI 6.1 update on S22 and since then I've been experiencing a huge change in battery behavior in my S22!
It's terrible! Battery life was not excellent but okay before the update, now - the phone barely survives 6 hours a day, and even if I am not using it I have to charge it up 3 to 4 times a day, it never happened before & if you start google map then done 2-3 hours max.
This has to be related to the update. I hope Samsung will fix this ASAP as this cripples the phone!
If the fix won't happen, and some rumors turn out to be true (Samsung trying to push users to get a new-gen phone) it'll be my last Samsung phone! I've already paid so much money for this model not to just cut my battery life almost in half by a software update just 2 years later!
#samsung #s22 battery #dosomething
20-05-2024 11:21 AM
what was you screen on time before and what is it now?
20-05-2024 11:23 AM
well, two years worth of charging discharging the battery will have a negative effect on battery life
20-05-2024 01:47 PM
20-05-2024 02:00 PM
What's is truer is that battery, any battery, suffers from ever reducing capacity over a period of time (it doesn't even have to be used) . Just the nature of things
21-05-2024 12:41 PM
22-05-2024 12:34 AM
*#0099# causes and error message of "connection problem or invalid MMI code". Any help is much appreciated as my S22 ultra's battery lasts half a day now.
22-05-2024 01:00 AM
22-05-2024 02:17 AM
Did as instructed. Fingers crossed that it works! Thanks!
