S22 Ultra signal/network problems
(Topic created on: 24-05-2022 07:56 PM)
krisstinel
Hi all, I got the phone last week, since then I couldn't have a decent conversation with it, signal drops all the time but I have full bars, Internet drops in the same time, I cannot listen to a full song on YT, if I'm on Bluetooth with the headsets, Bluetooth connection drops too, basically I have all the problems that are being reported all over Internet with this phone. Airplane mode/restart fix it for a while then it happens again. The rest of the phone is really realty great, I still vahe time till the end of the month to switch to a different phone but I really hope I'll keep this one. Is there any news that this will be fixed by an update or the phone is just rubbish and there's no hope? Cheers
P.S. even now when I tried to post this I lost the connection
76 REPLIES 76
Peter168
My problems was solved with the A13 update last year.
Works perfect after that.
Now im never install any new sw update
Churuakash
What app did you uninstall?
BR123
After update I also face the same problem, even 4G and full strength of network showing on screen ,I can not  connect to internet.
mark149
That is a beautiful phone .  It pains me to have to get rid of it.   My cell company took it back because it would not connect they way it should.  I had it for 3 months and after trying everything it wouldn't work .   I had to get nasty with them to take it back.    I was surprised to see one guy that said after update his worked,     The phone has a flaw that renders it useless ,  Don't let your return time expire .   I wanted it to work but it wouldn't/    constant drop calls never connecting.
Peter168
Mine still works.
Im dont install anymore updates after the Android 13 in April 2022., witch solved my problems, both with internet and bad calls
S22 issues
So mine was fine they did a new update and for about 3 months it terrible. I hate this phone want to go back to Google pixel. I can call anyone unless I'm on my home wi fi.
mike152
Well I bought a third s22 ultra, and it was the at&t U model. It has connected to data and Wi-Fi without problems. I even downloaded U1 software using odin and it still works fine. For some reason the two U1 models I bought directly from Samsung last year would not function properly.
