07-03-2024 11:36 AM
Samsung Note 20 Battery drain due to Google Play services after 2024 Feb security update.
Google play is draining the battery. Cant uninstall the app. Reverted it to the factory version still the problem did not get resolved. The device is dead slow and hot as a hot plate.
disabling the app is also not possible as all the google services are dependent on it.
01-08-2024 01:15 PM
I believe deleting the cache helped and a phone update fixed it. It was frustrating while it was occurring. The phone is working well now. If this helps, I have AT&T.
02-08-2024 10:32 PM
Hello, thanks for sharing.
I tried and it does not seems to make a difference. But then i have different chipset its 2.4GHz octa-core Samsung Exynos 990 processor, different than global version which I think you have in the US (at&t).
30-12-2024 02:20 AM
Any update on how to fix this issue?
Is Samsung going to help fix this?
