Samsung Note 10 Lite Battery Drain
(Topic created on: 27-03-2020 07:40 AM)
Amo2
Hello,
I upgraded from a S8Plus to a Note10Lite, and have noticed that the battery drain is very high.
Even on standby it consumes 1% per hour, and I have turned most things off.
When I go into the Settings/Apps and check each App for battery drain, the following show the highets -
Find My Mobile - 20% used since last Charge
Voice Wake Up - 20% used since last Charge
I've already turned both off.
Appreciate any ideas.
Thanks
Amo2
24 REPLIES 24
BandOfBrothers
Samsung Members Star ★★
After you've been using your phone for a day can you screenshot the battery stats and post them here @Amo2
If the phone is relatively new then the phone will still be learning your usage pattern and optimising.
A battery would be at its optimum output until it's been charged and discharged a few times.
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Amo2
Thanks I will submit usage pic once battery is recharged.
Can I ask what is the difference between the battery usage figures under each app as apposed to the battery usage figures under the device care?
i.e.
1. device care/battery/battery usage.
2. settings/apps/voice wake-up/battery.
Thanks
BandOfBrothers
Hey @Amo2
The Device Care option gives active and background usage.
The other is from since last fully charged.
Personally I tend to take more notice of the stats under device care.
Amo2
Hello,
But the device care shows usage since last charge too, but its not showing items such as Voice Wake-Up which under the App shows over 20% usage since last charge?
Bit confused.
Thanks
Amo2
BandOfBrothers
Hi @Amo2
From my initial look at your stats...
Your network signal is low which will cause the phone to work harder to maintain connection.
The App WhatsApp is a known resource hog. On my phone I close it down when not in use or add it to the sleeping apps section under device care.
I can see you use your camera quite extensively going from the battery usage along with the AR Emoji which are all using quite a chunk of your battery.
Amo2
Hello, understand that.
What I am asking is why is Voice Wakeup and Find my mobile showing high usage but are not showing at all on device care?
BandOfBrothers
I'm not sure.
Perhaps Give your Samsung Support Department a call to ask.
Amo2
Hi, I chatted with them they said Batt usage for these apps was fine -
Because they are not apps they are features of the android software find my mobile will always stay switched on as long as you have a Samsung account added to the device
