Note 20 Ultra Speaker and or bluetooth audio crackling
(Topic created on: 07-03-2022 11:37 PM)
Tizi1965
Since the 2 updates this year in aus my note 20 Ultra Speaker and or bluetooth audio crackling while playing music, reset the device all good for awhile then it happens again.
any ideas samsung
1 REPLY 1
mieloncom
Voyager
Firstly try wipe cache partition...
https://youtu.be/I9ataWjDxuQ
If you have sd card try remove sometimes a lot of issue's with external memory.
If you have bluetooth problem also you try change bluetooth settings in developer options 😉Screenshot_20220308-143750_Settings.jpg
