[Note 10 Lite] Battery Drain After Android 12 Update
(Topic created on: 01-04-2022 01:38 PM)
Sinaye
In February I updated my phone to Android 12. Since then I noticed that I can barely finish 2 hours with decent battery left. I don't know if this issue is isolated to me only or if others have experienced the same issue as well. Hopefully, this can be fixed with a software update.
1 REPLY 1
Beth_S
Pathfinder
Hi @Sinaye!
I recommend checking your battery usage to see if there are any particular apps draining your battery.
To check the battery usage:
1. From the home screen, swipe either up or down to access apps.
2. Select Settings.
3. Select Device care.
4. Select Battery.
5. Select Battery usage.
