Charging a battery once in less than 24 hours!
(Topic created on: 04-06-2021 05:42 PM)
efstathitsa
I have a Samsung note 20 and the battery needs  to be charged in less than 24 hours!!!Is that normal??
16 REPLIES 16
APARMAR
Troubleshooter
If you have the UK version that has the Exynos 990, then it is normal as the Exynos 990 is the worst when it comes to battery life.
efstathitsa
I am not sure ...I bought it in Greece and things are getting worse every day...I will need a power bank.
efstathitsa
Thank you 😊
antikythera
Black Belt
Are you in Greece at the moment and if so what is the temperature? Anything over 40 Celsius can cause battery cell damage when charging. Allow for sun through windows in the car or your home too increasing the heat on the phone. Always charge in a shaded area if possible.
Joeeye
Legend
Depends on what kind of user you are. If it's your light casual use, then that isn't a good sign. A heavy user of camera and games, video calling etc and its perfectly normal.
APARMAR
Troubleshooter
If you got it in greece then it has most likely got the exynos 990
APARMAR
Troubleshooter
I have some tips for you
• Turn on Dark mode
• Go to Settings, then Connections, go to More Connection Settings and turn Nearby Device Scanning off (it wastes a lot of battery).
• Uninstall any of your unused apps, it will help to save memory and reduce the background battery drain.
• Use a darker wallpaper if possible.
• Turn off NFC, Wifi, Bluetooth and etc when you aren't using them as it will save lots of battery.
Let me know if you see an improvement in battery life on your phone after you use my tips. Hope this helped!
efstathitsa
Thank you! I am currently in uk.Temperature rarely goes up to 40 even in Crete.Maybe two or three times per year.Thank you! Those tips are very useful!
antikythera
Black Belt
No problem , I actually use an old phase change material laptop cooling mat when I'm charging my phone and/or tablet. It's useless for laptops with fan vents underneath as it blocks them but is still good for mobile devices. Says it contains sodium sulphate on the hazard label
