Go to solution Solved
Sound notification when battery full
(Topic created on: 16-02-2022 04:09 PM)
Elljay23
Hi, please can you add the option of making a configurable sound when the battery charge reaches 100% so I know to turn the charger off.  Thanks 👍
Sean03
Pathfinder
You can do this in Bixby Routines. You can go to the Discover tab in Routines, then go to Adaptive Routines. It will be listed in there as "Get Notified When Fully Charged" routine.
12 REPLIES 12
Sean03
Pathfinder
woodlouse
Helping Hand
Or download "battery full notification " app from the play store. This allows you to set a sound when the charge reaches a percentage of your choosing. ( better for battery life if you don't charge more than 95 percent each time).
xSteveuk
Samsung Members Star ★
You don't need an app
Click on Notifications
System UI
Battery
SmartSelect_20220216-184419_Settings_2005_1645037059.jpgScreenshot_20220216-184901_Settings.jpg
Elljay23
Thanks but I don't get that option on my A52S. There's Charging Sound in System Sound but it only alerts when charging starts! 🤦‍♂️
Elljay23
Thanks 👍 Any idea how to get it to play an alert? I can see Beep Once and Play Music...?
Sean03
Pathfinder
This might depend on phone and OneUI version but you should be able to edit your "Then" conditions inside the routine. When you Edit the routine and tap the + sign to add a new Then condition, the Sound category and Notification category should have the custom options you're looking for
Elljay23
Thanks but nothing useful on my A52S... 🙁Screenshot_20220216-194659_Bixby Routines.jpgScreenshot_20220216-194646_Bixby Routines.jpg
Sean03
Pathfinder
would Read Notifications Aloud do the trick? that's what i use personally
Elljay23
Yup, it defaults to that. Will see if I can get used to my phone talking to me 😁 Thanks for your help 👍
