"Vibration sound for incoming calls" randomly activates
(Topic created on: 22-09-2022 03:58 PM)
Boska
The vibration sound for incoming calls (very handy with the weak vibration of the S22 Ultra) in beta 3, randomly activates. Most times when there isn't an incoming call.  Hope this gets fixed.
For now the only way to avoid it is to disable that setting
5 REPLIES 5
Aliceon
Have you got WhatsApp? Seems like opening that is the cause (try clearing recents and clear memory or force stop to fix) - another possible reason is there is a watch connected via Bluetooth. Disabling Bluetooth can also fix the issue for now
Juli3n
Big Cheese
Yeah I've also started a thread about this with WhatsApp specifically, so annoying
Corrupt22
Hi
The only way round it at the minute is to go in to sounds and vibration then system sounds, then turn of vibrate and system sound hopefully they, will come up with a fix soon
Corrupt22
Hi
MagdalenaPo
Beta Moderator
Beta Moderator
@Boska ,
Please report this bug in Samsung Members app > Error Report, making sure that system log files are included. 🙂
