High battery drain
(Topic created on: 07-11-2022 01:05 PM)
RobertLondon13
Since the update the battery on my new z fold 4 seems to not even last 5 hours of usage, I'm not using fast charge and I have most of the apps. To. Sleep and deep sleep, still from 10am (85)battery to 1pm (15%) something is not right
3 REPLIES 3
Tehki8
Voyager
Have you checked to see which app is causing the drain. Settings > Battery and Device Care > Battery. You should see a list of apps sorted with the highest usage at the top.
BarikUK
Helping Hand
Here is no issue with battery drain
| Samsung Galaxy S25 Edge Titanium Jetblack 512GB | Samsung Galaxy Watch Ultra | Samsung Galaxy Buds 3 Pro |
AnnaMaz
Beta Moderator
Beta Moderator
Hello @RobertLondon13,
Have you tried wiping cache partition? If you identify which app is causing the battery drain, you can also try clearing that specific app cache. And if nothing helps - Please send an error report via Samsung Members 😊
Have a good day!
Have a good day! ☀️
