Call problem
(Topic created on: 05-06-2026 02:38 PM)
John86
Pioneer
Just wanted to let you all know, i had a issue with my incoming calls diplaying private number, what i did was to put a o2 physical sim in and problem solved all contacts are now displayed, my original smarty sim has been transferred to esim but still has the issue it's a way of getting around the issue.
9 REPLIES 9
Xperixon
Pathfinder
If you using esim, under beta testing, very often need to go to sim-s and updating it. Like every 2 days
Brummie
I have the same problem. Smarty too since the update all i get is private numver on my esim though a second esim is absolutely fine. Ive tried everything possible and changed the esim too. Still the same. All works fine on a secondary Pixel phone.This is software issue.
Scratchworth
I believe there are a great many others reporting this issue, which only affects eSims. I am very keen to have this resolved as I already have an physical Sim in my phone so I have to use an eSim for the second line.
MartynaK
Beta Moderator
Beta Moderator
@John86
Thanks for sharing your experience — that workaround may be helpful for others facing similar caller ID issues.
It sounds like the issue may be related to carrier provisioning on the original SIM/eSIM setup, since switching to a physical O2 SIM resolves the caller ID display correctly. This points more towards a network or SIM configuration issue rather than a device/software fault.
If anyone else is affected, it may be worth contacting their carrier to re-provision caller ID services or testing with a different SIM to confirm the cause :hand-with-index-and-middle-fingers-crossed:.
Matt5ki
Not just esims.
EdwJ
But if the same ID mobile SIM card is put to the other phone model, it works as usual. SIM card fault or S26 software?
John86
Pioneer
I totally agree, I've stated all along that it's a software issue.
theoldone
Doh, only one thing changed ie the software from Samsung. Before the change everything worked fine with three network, but it must be a network fault. Your a moderator, not Samsung software so if you want feedback stick to moderating instead of trying to undermine what people are commenting on.
John86
Pioneer
Didn't work
