Battery is draining so much and my phone is getting very hot
(Topic created on: 08-12-2024 09:43 PM)
Haytch
Helping Hand
Any tips?
8 REPLIES 8
ShrekUI
xNightWulf
Navigator
My Battery is also draining alot faster than normal
Gav4b
Voyager
mines was like that until I cleared my system cache then I fully charged my phone and it's better then what it was before one ui 7
Connerj
I found that turning performance profile to light helped with battery drain. I did this despite clearing the cache as I was still experiencing battery drain.
Richmar83
Helping Hand
Try clearing the cache then give it a full charge to 100%.
After that if you do *#9900#, click on delete dumpstat log & then reset battery stats option lower down.
That's what I did and to be fair I'm getting better battery life now than under UI6
S24UltraUKuser
Helping Hand
My battery is better than before I went beta frankly. I did clear the cache also like Gav above said.
Archiejohn
Mines is the same.. I'm not liking this new update at all
AnnaMaz
Beta Moderator
Beta Moderator
Hello @Haytch,
Thanks for reporting! Please also send an error report through Samsung Members app so that the developers can take a look at what may be the cause 🙂
Have a good day!
