Battery drain
(Topic created on: 11-09-2022 11:42 PM)
shaw23
How is everyone finding the battery life on this beta? I feel my battery drains quite a bit quicker than usual. I appreciate it's beta and I have gave it since launch day to see if it would improve / settle but it doesn't seem to be getting any better. As an example fully charged my phone and have opened this app, read a question on Android auto, took 2 mins then started to type this post, and at the time of typing this Im now at 96%. I'm having to charge twice a day when previously 1 charge would see me through the day no problem. I've not altered my use or settings. (now at 95%)
9 REPLIES 9
foster2022
Same
nowdeleted
Big Cheese
What does the device care say?? As you can turn off the adaptive brightness and turn down the brightness to a level that suits you. Also look at what apps you are using. Netflix, prime, fb and Spotify love eating batteries.
Liam44
How do you get the android 13 update
Liam44
Where do you sign up for it
Antonz85
Pathfinder
Battery life for me on my s21+ is pretty much the same as before.
Or even slightly better actually
Its very optimized so far.
No complaints here really
GoanGeek
Samsung Members Star ★
Mine seem pretty stable at around 7 hours SOT with a bit of gaming and stuff.
The 100% to 93% is normal nothing to worry about.
I always do a wipe cache after every update
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
MagdalenaPo
Beta Moderator
Beta Moderator
@shaw23,
I understand your concern about the battery performance, as it is an essential part of the device.
Please keep in mind that during the Beta Programme, the battery performance can vary from user to user. This is one of the Beta's purposes, so that Samsung can test the software in many different ways. The system is still in the optimization phase and the battery performance can change constantly. Nevertheless, this should be improved with the official software release.
I hope for your understanding. 🙂
JAMES4578
Samsung Members Star ★★
Experiences will differ but no discernable effect on Battery life, only ocassional minor glitches.
JAMES4578
@Liam44 If you are eligible for the One UI 5.0 Beta  you will receive a notice in Samsung Members.  However be aware it is only available for unlocked non Branded devices and there will be a limited capacity.  No longer open for S22 series . Some information here https://9to5google.com/2022/08/30/galaxy-s21-android-13-beta/
