Battery Drain
(Topic created on: 24-10-2021 01:13 PM)
romanlinley
Today my battery drain is worse than yesterday gone from 100% to 55% just using phone 3 times . Sky news app and weather app
11 REPLIES 11
adamlee
Big Cheese
Beta 3 battery life isn't good for a lot of people. I'm disappointed we all reported it in beta 2, they didn't fix it and made it worse in beta 3
Barrie-Wilson
Navigator
My battery life was awful as well but I seen that wiping cache partition helps with a few things and I tried it and my battery life has now improved a lot. Might be worth a try doing that
JAMES4578
Samsung Members Star ★★★
Battery life would still seem problematic for many.   certainly still got  bit of battery drain (though not as extensive as some)  but do not think any worse for me thus far in Beta 3.
GoanGeek
Mine has remained same from Android 11
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
mark770
Voyager
May seem like a stupid question but this is the only element of my set up that has changed or updated. Since installing this beta version, the battery on my Galaxy watch 4 is draining ridiculously quick. In excess of 10% per hour with light/average usage.
KalEl84
Pathfinder
I did this too and I think mine has improved also.
MartynaK
Beta Moderator
Beta Moderator
@romanlinley,
I've also experienced a battery problem on my device 😔.
Could you report the issue via the Samsung Members app attaching log files? It would significantly help the developers to fix the problem :hand-with-index-and-middle-fingers-crossed:.
adamlee
Big Cheese
I've sent multiple on last beta and this beta, they haven't listened.
adamlee
Big Cheese
It's down to the phone detecting movement in the pocket and draining battery. That's what the camera service wakelock is, was fixed in October patch on android 11Screenshot_20211025-140634_GSam Battery Monitor.jpg
