Battery drain
(Topic created on: 17-08-2025 04:43 PM)
Cricket14
Having battery drain in the Bate on my S24 any hints why
5 REPLIES 5
Bindex
Samsung Members Star ★
Are you talking about the beta?
Tech Enthusiast | Need tech help? Just drop me a message!
james887
If your on the beta id try clearing the partition cach, on one UI7 my battery was horrendous, 2 to 4 hour and it was flat, I'm getting about 10% better battery on oneUI 8,
Still not good but any improvement is welcome,
Base s24 exynos variant
Bindex
As James suggested, doing a clear partition could fix your issue; here are the steps below to do a clear cache partition:
To clear your phone's cache partition:
  1. Connect your phone to a PC.
  2. Turn off your phone (it won't enter Recovery Mode if it's on).
  3. Press and hold the Volume Up and Bixby/Power keys simultaneously.
  4. Once the Android Recovery screen appears, release both buttons.
  5. Use the Volume Down button to highlight "Wipe cache partition."
  6. Press the Power button to select it.
  7. Use Volume Down to highlight "Yes," then press Power to confirm.
  8. After the cache is cleared, press the Power button again to reboot your device.
Chris_F_Design
Voyager
Same. I've tried resetting my cache, hopefully it improves. It was the main thing I was looking forward to, some decent power optimisation.
MartynaK
Beta Moderator
Beta Moderator
@Cricket14,
Battery drain can occur in early beta versions due to background processes or apps not yet fully optimized for the new software.
I recommend checking for any high-usage apps in Settings > Battery and device care > Battery.
If the issue continues, please report it via the Beta Feedback option in the Samsung Members app and include log files to help our developers investigate.
