Soundbar bluetooth is out of sync and plays audio at wrong speed
(Topic created on: 28-12-2021 07:49 PM)
MattoKan
I bought a soundbar and subwoofer about two years ago. Not sure of exact model. I have one old macbook that works fine when connecting via bluetooth.
I have two newer laptops, one macbook M1 and the other a Windows machine, these both have issues with connecting via blue tooth.
1) sound is out of sync with visuals (we are watching movies). So out of sync that the "audio sync" options have no  real effect on them.
2) The pitch of the sound is low. Meaning, all audio is playing back at the wrong sample rate. Sounds like a 48k vs 44k issue.
The picture quality is much better with the new laptops so we would prefer to use those but the audio is so out of whack that its not doable.
Did some bluetooth specification change along the way to make newer machines incompatible with older technology?
Odd that the old machine works fine and neither new machine works. I have done a fair amount of googling and have seen a few mentions of this but no ideas on how to fix.
Any thoughts would be appreciated. Thanks!
4 REPLIES 4
xSteveuk
Samsung Members Star ★
Hi,
This page maybe helpful
Soundbar is out of sync with the TV
https://www.samsung.com/us/support/troubleshooting/TSG01110022/
MattoKan
Hi thanks for the response. I have seen this page before and its more severe than just a slight out of sync. These adjustments dont come close to fixing the sync issue let alone the pitch issue. Thanks though!
MattoKan
I find it odd no one has seen this issue yet I have it on two different devices from two different manufacturers.
TabbHonmin
Hello,
I have the exact same issue with a mini PC and a soundbar (HW-T420). I just posted here.
Did you find a solution to your issue ?
