02-11-2020 12:29 AM in
Audio & VideoI have a HW-Q60R soundbar and a Q60 TV. The sound coming out of the sound bar sounds like people are talking into can. It almost sound like the midrange has a lower volume on songs and some voices are hushed in movies. Not sure whats going on. The TV speaker sounds better. I've tried using both optical and HDMI cords with no change. Tried resetting sound settings. Tried changing a bunch of different things. Not sure what to do. Any suggestions
22-12-2020 10:54 PM in
Audio & VideoHave a similar problem with my HTW 560 Soundbar. We sit quite close to the TV, and when we have the Soundbar at low volume, the speaker rumbles. It does not seem to handle the low volume. Quite disappointing. Hope there is a solution.
03-02-2021 07:07 AM in
Audio & VideoI suspect this sound bar is a cheap prom product. Sound quality is horrible... at lower volumes, the midrange and treble is sometimes imperceptible... max volume is laughably low...
we need help from Samsung tech support
06-03-2022 01:00 AM in
Audio & VideoI’m having the same issue. Did you ever figure it out?
