19-09-2021
11:38 PM
- last edited
21-09-2021
11:55 AM
by
AntS
) in
Help, I have a Samsung ms650 sound bar and just bought swa9100s wireless speakers. When I follow the instructions they won't connect. It say to turn sound bar off make sure blue light is flashing on speaker reciever and then press the mute button for 5 seconds till it says I'd set I manage this OK but just won't connect. Tv sound bar all on same network.
20-09-2021 04:53 PM in
Audio & VideoHi @Grayson6 The LED indicator should blink before turning solid blue, is this the case? You could turn off the Soundbar and try again. If after the process you get a red light though you need to press the ID set button on the wireless receiver for 5-6 seconds with a pen tip until the indicator blinks blue before following the set up process again. see more here https://manuals.plus/m/802d7d5d8967c23023d715f1cf1e48b0cd2768211466aef3859bf0aad6e7dd66_optim.pdf
If still issues idea to reset your router by switching off at mains.
One Ui 5.0,Android 13 .
