How do I wall mount rear speakers for HW-K950?
(Topic created on: 06-04-2018 02:13 PM)
TonyWalsh
I've just received the HW-K950 with the rear Atmos speakers and want to wall mount these. I can't find an appropriate solution.
Either the brackets are too wide so won't hold the speaker, or the max weigh is less than the 8kg reccomended in the user guide that came with them.
Has anyone else found a solution?
Thanks.
1 REPLY 1
Aamirio
It's a really good question. I just bought B-tech BT77 mounts and when I came to mounting it I realised the speakers were not wide enough, so frustrating. Did you find a decent pair of mounts in the end?
