Problems with Camera because of Sun light - software or hardware problem!?
(Thema erstellt am: 04-09-2021 02:23 PM)
1252 Anzeigen
MajittoKun
Dear community,
I just noticed that when I take a photo that includes sun light or sun light reflection on glasses/windows, I get yellow distortion in my photos
I wonder, is this manufacturing issue? Or software? Or misusage?
Have you faced this problem before and what are the solution?
Noticed the yellow distortion on the flag
Here is another example on the right, beside white pants
Thank you and looking forward to hearing your solutions!
11 Antworten
Sungur
GrandMaster
Hello! MajittoKun.
I think thats a Softwareproblem. Because the sun is not so big on the Photo.
Make this 2 things:
1. Go to the camera app》 Hold the camera app》 on the small i at the top right》 Memory》 Empty cache and still delete data.
2. Switch off the mobile phone / tablet》 Connect to a PC / laptop / console with a charging cable》 Hold down the power button and the volume up button (+) for at least 5 seconds》 A so-called "Recovery Menu" appears》 There, please click once on "Wipe Cache Partition" " YES "》 And then click on" Repair Apps ".
Your mobile phone / tablet will be restarted and the apps will be optimized there (there is a box below after restarting)
__________________________
Distress:
You use the "Recovery Menu" with the volume up key = up and with the volume down key = down and confirm with the power key = YES.
_________
A wipe cache partition does not erase the data of your cell phone / tablet, it erases the garbage from the previous version!
_______
Many greetings, Sungur
JöPi
Important: Do not select the factory reset in the recovery menue
JöPi
Sorry für's einmischen 😶
Sungur
GrandMaster
Nicht schlimm..
LW0108
Samsung Members Star ★
This is normal. It always depends on the angle between the camera and the sun. Do what Sungur already said.
ErdbeerSchrippe
Das war schon immer so. Es ist nunmal so, wenn Du direkt gegen die Sonne fotografiert, dann erscheinen diese gelben Punkte.
Halte das Handy einfach etwas anderes und lasse nicht gerade die Sonne darauf scheinen.
ErdbeerSchrippe
Versteh Deine Frage überhaupt nicht. Schau auf das Haus. Es spiegelt voll die Sonne gegen die Scheibe.
Ist doch normal, das so was passiert. Du musst ja so nicht halten, und ändere dann den Winkel.
judgeandy
Look at the screenshot.
The phenomenon is called lens flare. Screenshot_20210905-160927_Samsung Internet_191991.jpg
MajittoKun
Yes I know a ray always shows from the sun, I use cameras since 15 years! But this yellow flare/distortion is not normal and should not appear
