Help, i have some problem with samsung travel adapter 25w model ep-ta800
(Topic created on: 05-11-2023 04:03 PM)
R4ze
Has anyone encountered a similar problem charging a Samsung s22 or other phone with this  travel adapter 25w ep-ta800? When I put the phone on charge, it starts charging and after a second it just stops, then it starts again and stops again. Does anyone know what the problem could be?
3 REPLIES 3
R4ze
I’ll also add that everything is new and literally just taken out of the box.
Piper123
Samsung Members Star ★
I would return it for refund or replacement. Whilst they aren't expensive, I wouldn't risk it myself.
S24 Ultra
helper-K
Navigator
I suggest not using it in case any electrical problems might occur if you try to repair it yourself or damage it I do not currently know what it is I suggest you either return it and do not repair it yourself or go to the Samsung store wherever you live and see if they can give you a replacement. Sorry that I cannot give you the full answer
