Does 15W Duo Super Fast Wireless Charger charge through phone case?
(Topic created on: 30-04-2022 06:43 PM)
paulg32
Hi everyone.
I am looking at buying the '15W Duo Super Fast Wireless Charger Pad EP-P5400TBEGGB'.
Could someone please tell me if this device will charge my phone through its case?
I have a Galaxy S22+ with Smart LED View Cover (EF-NS906PBEGEW).
Thanks,
Paul
5 REPLIES 5
LeoXXL
Pioneer
It's not about the charger, it's your case if it will allow the charge to go through, some cases are too thick or charge resistance to allow charging. If you have used your case before with any wireless charger then you are safe to say it will be good.
paulg32
Thanks for the quick reply Leo. Unfortunately I don't have any other wireless chargers to test it. I don't really want to buy one unless I know for sure that it will work. Having to remove the case every night would be a real pain 😞
Snapper99
Voyager
While I don't have a Samsung Duo, I do have a Samsung Trio Wireless Charger and that charges my S22 Ultra 1Tb with no problems while it's in a Smart Clear View Cover (EF-ZS908). It also charges the S21 while that's in it's Smart View Cover and a Watch all at the same time.
(Msg to the OP, I think you have put the serial number for your case up, instead of the model number. You may wish to edit your post...)
Current Phone S24 Ultra (1TB)
Previous phones S21 Ultra, S22 Ultra, S23 Ultra.
paulg32
Thanks for the info. Sounds like it will probably work then 😀
Krisalex79
Helping Hand
yes, it charges without issues with the vast majority of cases. if the case is full metal back, it may not charge.
The FACT that i PRETEND to believe you, DOES NOT mean i actually believe you.
