Go to solution Solved
Serious Problem- ZIP code for Card Details.
(Topic created on: 10-07-2024 11:35 AM)
Anonymous User
Not applicable
Hey there, I'm trying to add my credit card to Samsung Wallet, and the only thing that is stopping me is entering the ZIP code. I live in the UK, so I would use a postcode. The ZIP code field only let's me enter 5 numbers, whereas postcodes have more than 5 characters and letters.
Please advise, thanks.
Robin999
Legend
Well, as you are currently experiencing, yes, it's a problem as you can't use Samsung Wallet. With regards to 'changing it', then you'll need to ask elsewhere as we are unable to give instructions regarding flashing, rooting, etc as it's against community guidelines. Your best bet is to Google it. With regards to the actual purchase via Amazon, then you could try getting your money back, especially if the phone was advertised as for use in the UK.
11 REPLIES 11
Robin999
Legend
Hi, is your device a stock UK handset?
Anonymous User
Not applicable
I'm not sure, ordered off amazon.
Robin999
Legend
Thanks. Used or new? It could be that the device was meant for another region. Your CSC code will confirm this.
Anonymous User
Not applicable
I know my CSC code and the phone was refurbished.
Robin999
Legend
Post a screenshot so we can advise further. Settings>about phone >software information > service provider software version
If the phone was refurbished, then it might not be intended for use in the UK.1720609116853.jpg
Robin999
Legend
United States CSC code. Suspect the phone has been flashed too.
Anonymous User
Not applicable
Is that something to be worried about? Can I change it?
Robin999
Legend
Anonymous User
Not applicable
OK thanks 👍
