Crackling noise from one connect cable?
(Topic created on: 16-10-2019 10:09 PM)
Massig
Pioneer
I noticed that if you touch the one connect fibre cable 2019 on a Frame TV it makes a crackling noise....
It seems fully inserted...
Anyone else?
1 REPLY 1
AndrewL
@Massig: This is quote difficult to gauge from here. By chance do you have access to another cable that you can try to see if the issue persists? Have you tried removing the cable and blowing into the port to remove any trace dust that might be a contributing factor?
