Strava (I think) draining battery of Galaxy Watch 3
(Topic created on: 17-05-2021 02:26 PM)
MrsWater
So I bought a Galaxy 3 mainly to use Strava on to record bike rides.
It drains the battery within 4 hours which usually means a ride is lost.
I have removed all apps apart from Strava, all connectivity is switched off apart from location services.
I have already done a factory reset and the watch has been back to Samsung, not sure what they did but it didn't solve my problem.
What can I do to stop this battery drain?  it renders the watch not fit for the purpose I bought it for.
Any advice/suggestions much appreciated.  Am so disappointed by the watch!
6 REPLIES 6
Pugs1957
SuperStar
Strava eats batteries whether using a watch tablet or otherwise. Doesn't matter if it's iPhone or Android. There are many complaints about this widespread issue.
MrsWater
Thanks for your response.
Strava doesn't eat my phone battery - Samsung S7 edge uses 15% in the time it takes the watch to drain.
Anniebell33
I have just done a 5 hour walk. My watch died at 4 hours on strava. But my other halfs apple watch was fine.... grrrrr so annoying.
MrsWater
I share your pain & frustration.
I gave up on my watch for Strava.
Wish I had an answer for you but nothing I tried solved it.
In fact tried it again recently, more in hope than expectation, and had same problem.
Anniebell33
So annoying. Especially when the apple works fine.
Looks like I'll have to use my phone for long distances. May try ring Samsung and have a good moan to them about how much battery the apple has left on it.
