Samsung watch battery drain
(Topic created on: 02-02-2024 09:14 PM)
DustyMacd
Hey everyone,
I've got a watch6. And I have a battery drain issue. I have had 2 weeks of amazing battery lasting around 1.5 to 2 days. But suddenly now it is going down in less than 10 hours. I can't figure out why. There is no extra use on it and I've not changed any settings.
It happened before and I did loads of research I ended up clearing the apps up. But I tried that again and it doesn't seem to work now.
Any help would be awesome.
1 REPLY 1
GreaterGalaxyUK
Helping Hand
Have you turned off:
-Flick to show time
- constant Heart Rate Monitoring?
- constant oxygen monitoring
- AOD?
I found turning these off for my Watch 5 gives me almost 3 days. Albeit the watch 5 44mm has a bigger battery.
Alternatively, contact Samsung support and they can take it in for repair. My watch 5 stopped connecting with my S23+ and I sent it in and was back within a month fixed.
