Samsung Health - Maps for a running workout?
(Topic created on: 02-12-2020 12:25 PM)
Eurodjuro
Hi Folks,
Just wondering if the Samsing Health app on my Note10 will capture a map of my recent run - the time and pace is there but no map....is there a way to get this data or was it not captured for the run that I did?
Cheers,
Djuro
8 REPLIES 8
Eurodjuro
see attached screen grab from my phone
mb2706
Pioneer
Did you get a gps lock before you set off?
Eurodjuro
Not that I am aware of....
mb2706
Pioneer
Try getting a good gps signal before you set off, if it doesn't get a signal before you start it doesn't record where you went
Eurodjuro
thanks- admittedly I just set off without really checking
Eurodjuro
in fact it says GPS is not in use? see the attached image
mb2706
Pioneer
Silly question, is location turned on?
Eurodjuro
yeah - even enabled everything as a just in case but still no luck
