Green box on top of lockscreen/always-on display
(Topic created on: 28-01-2019 10:06 AM)
DanielHermansen
I have an error on my Galaxy Watch 46mm, that I can't seem to find a solution or explanation for.
When i have "always-on display" turned on - i tend to get a green box on the top of the screen whenever there is a notification and the yellow dot appears. But it is not consistent.
I can't find a pattern on when the error occurs. And it happens with all the different watchfaces I have downloaded.20190128_103512.jpg
am I the only one having this problem?
1 REPLY 1
MasukaH
Voyager
Hi @DanielHermansen
Where did you buy your watch? Have you tried a quick reboot? Does this happen when AOD is disabled? Keep us posted!
