01-02-2017 11:00 PM
Hello
i have bought a Gear S3 Classic and paired it to my Xperia XZ.
All works brilliantly except:
Never thought I'd be interested in the ***** Tracy feature but as it's there I wanted to try it.
Unfortunately I can't get it to dial out.
if I ring my mobile I can only accept the call on watch but must use the phone to speak etc.
So I'm trying to figure out if it is a phone compatibility issue or not.
Is anyone in U.K. and can make direct phone calls from S3 paired with any phone?
thank you
Solved! Go to Solution.
28-02-2017 11:15 PM
01-03-2017 08:28 AM
Glad you got it working!
To transfer a call back to the phone is easy. During the call on the watch, there will be an on screen icon shaped like a smartphone which you tap to transfer.
23-02-2017 10:22 AM
28-02-2017 11:15 PM
01-03-2017 08:28 AM
01-03-2017 10:57 PM
Excellent.
Thank you.
