Go to solution Solved
Galaxy watch 4 Problem connecting Nothing Phone 1
(Topic created on: 29-01-2023 01:59 PM)
Nothing Phone 1
I have a Smartphone from the Brand Nothing, model PHONE 1. I have a problem configuring my Galaxy watch 4 with my smartphone. The problem is software I would like Samsung to resolve the situation.
3 Solutions
Nothing Phone 1
WhatsApp Image 2023-01-29 at 13.16.16.jpeg The device is not compatible with the application.
MOBILEUNITED213
Navigator
Yes that's what I mean
12 REPLIES 12
-Robot-
Samsung Members Star ★
Download Samsung wearable app
Nothing Phone 1
CoolMcCoolson
Voyager
Nothing Phone 1
the problem continues
CoolMcCoolson
Voyager
What happens when you press install?
MOBILEUNITED213
Navigator
This phone is not compatible with Samsung watch
Nothing Phone 1
I can install the application and I can also connect the bluetooth. When the configuration part arrives, it gives an error and does not allow me to configure the watch.
Nothing Phone 1
The first time I was able to perform the configuration on ANDROID 11, after the update to ANDROID 12 it was no longer possible.
Nothing Phone 1
Samsung with an update manages to solve this situation.
