Galaxy Fit battery usage
(Topic created on: 05-05-2020 12:21 PM)
MattVanSaber
Hi, is there any way to check when fit  band battery was charged last time or its usage? Something similar to battery info on any Samsung phone?
2 REPLIES 2
mb2706
Pioneer
Does the fit work with the galaxy wearable app? If it does try going to about watch, in the next screen click on the battery circle. This shows some battery use in there
MattVanSaber
It is using Galaxy Wear app and its showing the percentage circle but you cannot click it.
