19-03-2024 10:50 AM
Having been a very happy Galaxy Fit 2 user, I bought the Galaxy Fit 3 the first moment it was available.
The device is advertised as getting 13 days of use on a single charge, but I have not found this to be the case AT ALL.
At most I get about 6 days charge, when with the Galaxy Fit 2 I often would get more than 2 weeks before I needed to recharge it.
Not being anxious about battery level is the main reason I picked these devices.
But the interesting thing is that I've been watching it closely and it seems that during the day it generally performs very well with minimal battery usage. However at night, I put it into sleep mode and it often drops 10% or more overnight - despite the fact that the screen is off the entire time.
I immediately assumed this was due to the sleep tracking features (blood oxygen, snore detection), but I turned all of them off. I then thought perhaps it's the heart rate every 10 minutes, so I switched that to manual only yesterday morning and fully charged the device. By yesterday evening when I went to put it into sleep mode it was still at 100%. I woke up a few times during the night, and as is often the case I noticed that the green light at the back of the watch was flashing a lot and for what seemed like a very long time. Considering I had disabled regular heart rate monitoring I don't even know why this was coming on at all. Some points I would read for a few minutes and see the green light emanating from my wrist continuously.
Anyway - I woke up in the morning after about 8 hours sleep and turned off sleep mode. The watch was at 87% - a drop of 13% overnight. That is basically the opposite of what I used to see with my Galaxy Fit 2, which usually, with the screen off overnight, would rarely drop anything overnight.
Anyway, I'll continue to see what happens with it now that I've disabled heart rate checks every 10 minutes - but I must feel like something is wrong and either the hardware or software has a bug that needs to be fixed.
Software Version: R390XXU0AWLL - I've checked for update and found none.
I'm almost tempted to go back to my Galaxy Fit 2 which even after multiple years is still regularly lasting for two weeks without charging.
12-06-2024 04:00 AM
I'm fairly unhappy with the battery life with my fit 3. To me, the main issue is the raise to awake feature. It's unbelievably too sensitive. As I have to type a lot on my PC, I see the screen turning on very frequently. I thought of disabling it, but what's the point of using a band if you disable this feature. I noticed only minimal difference if I set the heart rate monitoring from continuous to 10 minutes. Even the screen turns on frequently when I sleep. There are simply many software issues with the battery in this device. Samsung should fix those with update.
12-06-2024 08:26 AM
I will say that the most recent update (R390XXU0AXE1) has definitely improved a few things. Putting the watch into Sleep Mode has stopped hammering my battery for 8-10% overnight. It now only goes down a couple of percent points. Not sure that the update changed anything with regard to the raise to wake feature - but I definitely agree, it feels a bit useless with it turned off - as I'll often need to activate the screen when my other hand is busy, so the raise to wake feature is definitely one I refuse to disable.
21-06-2024 10:46 PM
How are ya'll getting so much battery time?
I read this post cause I'm getting 4 days max!
- I use AOD
- I only use 'tap to wake', and 4 secs screentime
- I turned off heart & stress checks completely.
- I do walk a lot so I have automatic walk detection
- I use sleep mode but disabled sleep monitoring (I just use it to turn off the screen)
- I even turn off my Bluetooth at night so the band is disconnected from my phone.
- I use adaptive brightness to save battery
What could be causing this?
I'm losing about 25% each day 😭
05-07-2024 08:49 AM
Worse than your situation. Battery doesn't last more than 2 days
17-07-2024 01:36 PM
hello. 9 days is fantastic comprign with 3.8 days i have. pls share your settings and what do you believe it is the most battery consumming setting.
thanks. Cristian
17-07-2024 05:06 PM
hello. Can you share with us your settings?
thanks,
c
17-07-2024 05:41 PM
- Even w/ new upgrade firmware, 4-6 days is max.
- Have noticed that first 1-2 days it stays above 90% but after that drops very fast; so it is not related to my standard sleep etc. settings. I turned off Wrist to Wake etc.
- Some types of activities may speed the drain up but have not found a pattern - it is very inconsistent if it does 4 days or 5-6 (max).
- Unless Samsung has some detail app usage metrics built-in (which I doubt - have not been too impressed with the overall engineering), not sure how to track what activity/behavior is causing this. Not sure how even they would know, or if they are paying much attention to this 🙂.
19-02-2025 11:04 PM
15-05-2025 04:28 PM
Buenas tardes, me acabo de comprar el Fit3 la semana pasada. Y por lo menos yo, sigo con este mismo problema que tienen... me dura como mucho 4 días. Alguien le pudo encontrar la solución en este año que pasó?
