Sluiten
annuleren
Resultaten voor
Zoek in plaats daarvan naar
Bedoelde u:
Spring naar oplossing OPGELOST
Oorspronkelijke onderwerp:
Galaxy Buds3 pro multiple problems
(Onderwerp aangemaakt op: 01-02-2025 07:35 AM)
217 Weergaven
AaronTen56
Opties
Hey!
I recently purchased the Buds3 Pro from an official Samsung store here in Paris, France (Samsung - La défense) and have been having issue after issue.
I there's two problems that I can't seem to get over when using the Busd 3 pro.
Constant loud hissing from left bud when in ambiant mode, and also a painful high pitched squeal when insterting the left bud.
Right bud not recognising my ear, no matter which tip I use, it's a battle to use them and not be disconnected and connected constantly. No issues with other buds in the past.
I've tried everything in the book to fix this, reset and pairing again and again, as well as the other "fixes" suggested here and elsewhere.
What should I do? Do I need to return them? If so, would I need to return to the same store?
Appreciate any help/feedback
Thank you!
1 Oplossing
Geaccepteerde oplossingen
Oplossing
Ajay-A
Opties
Hallo @AaronTen56,
Thank you for your message about this. We strive to ensure our customers can enjoy our products and expect hight quality from us. You can register it for a repair through our pick-service. See the link below for this. Can you keep us updated?
https://bit.ly/3J4HpwQ
With kind regards,
Ajay
Bekijk de oplossing in de community in het oorspronkelijke bericht
1 Antwoord
Oplossing
Ajay-A
Opties
Hallo @AaronTen56,
With kind regards,
Ajay
