Galaxy buds pro fitting issue
(Topic created on: 23-04-2021 10:21 PM)
Fiz7863
Voyager
Since i have got my buds pro, they either hurt my ears or fall out. I have tried different sizes it didn't help.  I used to have galaxy buds that came with s10. They were great in terms of fitting as they had wing tips. Unfortunately gave them away as recieved pro ones with s21 ultra. Any hints or tips for good fitting n not painful to ears?
4 REPLIES 4
Joeeye
Legend
I had that problem with them, especially the right ear. I since have gotten use to them over the last couple months. They still do tend to fall out though. Probably not the advice you want, but if you can bare with them, they do get less uncomfortable (at least I found that), albeit, the first month or so wasn't all that pleasant to use. Now they just feel OK and don't typically leave pain in my ears anymore
99kingcone
Pathfinder
I wear hearing ***** and I find that if you smear the edge of the ear with a dab of vasilene or gel that does the trick 🤔😏
Fiz7863
Voyager
Thanks ll keep on using them to get more used to them then. 👌
Fiz7863
Voyager
Thsnks might give that a try then
