Galaxy buds pro do not charge in case if not plugged in
(Topic created on: 13-04-2022 12:35 PM)
Jason 1975
Hi
My Galaxy buds pro worked just fine until the day decided not to.
The earbuds lignt inside the case does not work anymore when I put the buds in the case.
and the earbuds do not chagre once in the case except when I plug the case.
I tried to reset, to upgrade the software, to clean the pins
nothing worked.
Do you have any idea how to fix this?
Thank you
1 REPLY 1
SereneH
Hi, @Jason 1975
If the red light doesn't come on, this suggests that your case has a flat battery.
With the Galaxy Buds still in the case, charge the case using the charging cable.
Leave the case and Galaxy Buds to charge for 10 minutes.
