Go to solution Solved
Galaxy Bud pro3 Ambient sound issue
(Topic created on: 08-12-2024 09:04 PM)
Suchy1977
Pioneer
Hi all, I have recently purchased a pair of Galaxy Bud Pro 3 and as gr8 as they are I came across a little issue, when listening to my fav tunes, I can't sing along as the ANC kicks in even when turned off! As soon as I lock my phone and put it in my pocket, it seems to auto turn back on the ANC so when I sing ( badly) my music go's very quiet. Is anyone else experiencing this same issue or am I missing something simple? FYI S24 ultra on latest firmware and everything is updated (UK)
2 Solutions
Windroid
Troubleshooter
That means your voice detection is on. This is a feature that lowers the music volume or whatever you are playing for 5 seconds or 10 or more so you can talk to someone and hear them clearly. If you go to the buds settings while they are connected, deactivate voice detection.
GusB
Samsung Members Star ★
^^ probably this ^^
Also consider putting into ambient sound will allow some external noise (i.e your wonderful singing) to be heard
**Photography IG: @slappa_da_tubs | Travel Vlogs YT: GusBan Travels **
5 REPLIES 5
RahimAdoborn
Are you sure Voice Detect is not on?
Windroid
Troubleshooter
GusB
^^ probably this ^^
Suchy1977
Pioneer
Tha ks I will give this a try and post result 🙏
Suchy1977
Pioneer
Thanks all for the replies . You were correct, I had voice detect turned on. I didn't even know that was a setting. Thank you for the advice and lesson 👍🏼
