Go to solution Solved
Earbud connection Bluetooth/WiFi
(Topic created on: 01-02-2021 05:37 PM)
Debbie1804
Do galaxy earbuds show as a connected device on the broadband router. The reason I ask is simply to determine if the unknown device showing on my broadband app is simply the connection to my buds or a connected device from an unwanted source/security threat.
Any insight appreciated.
Pugs1957
SuperStar
No, the earbuds are Bluetooth so your router won't see them. The router is probably showing a device in your vicinity, not necessarily connected to your network.
1 REPLY 1
Pugs1957
SuperStar
