Buds plus low volume in one side
(Thema erstellt am: 17-11-2023 08:44 AM)
203 Anzeigen
ssg_commando
Hi all,
Recently my baby put my Samsung galaxy buds plus into his mouth (poor baby and bad parenting from my side!) and after this incident, right piece has now low volume. I have tried resetting my buds, cleaning my buds with brush and played high bass and pitch audio in max volume but all of these did not help. I am not sure how I can fix this issue. So I have 2 questions:
-) I believe my right side of buds has lowered volume(not muffled sound) so it seems I need to turn its individually volume higher but I don't know how I can do it?
-) Any way that I can fix this issue at all?
3 Antworten
Darkseid48
On my Galaxy Buds 2 i had a similar issue, might be the same problem for you that some liquid got pushed through the mesh and now blocks the sound from the inside.
What worked for me was to remove the black mesh that covers the hole with the speaker inside, i used a small needle to get it out without destroying anything.
As it turns out the dirt or liquid pushed through so i had to clean the inside of this mesh, after cleaning it on both sides i glued it back in place and since then the volume is back to normal again.
I hope i could help you
ssg_commando
Thanks for your sharing your experience. I will try it!
ssg_commando
I opened the metal grill of buds by prying using needle. There was a black filter/rubber like thing, I cleaned it using isopropyl and it worked. Thanks for the help!
