Battery drain active 2
(Topic created on: 06-06-2021 09:53 PM)
sequincrayfish
Pioneer
I was wondering if anyone else has had any battery drain problems with their active 2 watch, have had no trouble at all until after two weeks of having it the battery had suddenly dropped from 100% to 18% in about 4 hours, I have the normal health and notifications running in the background but not much else.
Any ideas or info will be much appreciated thank you in advance
5 REPLIES 5
Fiona26
Samsung Members Star ★
Have you rebooted the Watch recently?
sequincrayfish
Pioneer
Just tried it about an hour ago so need to charge it and see how I get on, hopefully it will be ok
Fiona26
Rebooting mine helped with battery drain. I thought maybe it was my new s21 ultra that caused battery to be going quicker then usual. But a reboot seemed to be all it needed. Hope it solves it for you.
sequincrayfish
Pioneer
I wasn't too sure really what it was, it's so easy to download loads of faces and everything and not think it will have an affect ha but we will see. I did have the transferring file notification pop up a lot on my phone but nothing would come up when clicking on it. Thanks for your help
Fiona26
If it does continue back up your watches data and factory reset.
