What is MRT Option > Front Color
(Thema erstellt am: 13-09-2021 04:15 PM)
7700 Anzeigen
masterx1
Can anyone explain the Front Color option just a little bit? And maybe what MRT stands for?
3 Antworten
PoPeYe
Samsung Members Star ★★
Moin (means hello 😁),
MRT is a part of the Service-Menu of TV's. But be careful if you don't know exactly what you do.
They say...
Option -> MRT Option You should not change the inconspicuous Front Color, since many of the TV's functions are controlled here. If you select the wrong value from the list for Front Color, some features will no longer work. In this submenu you will also find the TV Plus Support option described above, which you can turn off here.
Greetings...
PoPeYe
masterx1
Yeah thank you I read similar things but I wonder why all those Front Color things have absolutely no impact if I change them 🤣 or maybe it was luck. Tried like 10 to see anything but no. Still wondering what MRT stands for. Mighty Remote Technician?😅
PoPeYe
Hey...
found a Note..
"MRT Option (Multiple Render Targets)"
I sendet a message to you..
Greetings...
PoPeYe
