Voice Control, sorry I failed to recognise that.
(Topic created on: 18-01-2020 03:16 PM)
Dean1969
I've had this issue and fixed it last today.. go to settings voice control change the language from UK English to US English.
works perfect now.
hope it might help.
3 REPLIES 3
JAMES4578
Samsung Members Star ★★
works perfect now.
hope it might help.
Glad sorted @Dean1969 , though not all Tv's will  have this option in settings and will usually  work ok if correct country set.    Take you are based in US, is it american model?
A method for solving issues not otherwise fixed:
Turn off TV
Unplug from power point
Hold down the return and 4 colour button till remote stops flashing
Reconnect power plug to wall socket
Turn on   the TV
Remote should then  resync to the TV and if so the voice  control will be active.
Problems are sometimes caused by server issues.
Dean1969
No mate UK ... had the telly from Curry’s a couple of years back 👍
JAMES4578
@Dean1969  oh right thanks, just thought might be as using Us English but obviously that's the one that worked for you.
