Go to solution Solved
UHD TV HDD USB port USB3 or USB2
(Topic created on: 13-03-2018 09:36 PM)
DCH1
We have a UN50MU6300F.
Are the usb ports usb2 or usb3?
Don't see any point in using a newer drive if it isn't utilized...i have lots of older usb2 drives.
JAMES4578
Samsung Members Star ★★
Hi @DCH1,    it is USB 2.0- 3.0 should work at the lower speed.  See detailed model specifications here UN50MU6300
2 REPLIES 2
JAMES4578
7alhoul
Navigator
Hi,
Le port USB avec 5v/0.5A c'est le port USB 2.0 et le port avec 5V/1A.
THANKS
